Good day to everyone,
I bought an NVR and 16 ip cameras for my office (specs and configuration below). I don't have any problems with live view or playback through my cell phone (hik connect) or, through the web browser at main stream or sub-stream settings. When I try to live view 4 cameras on the tv with main stream settings I get the message "not enough resource for decoding. Try switching to sub-stream". With sub-stream settings the 4 cameras work fine.
I did some reading on decoding and tried live view with a 1x1 grid (only one camera) and main stream settings with no luck. The NVR specs says 1-ch@12 MP (30 fps)/2-ch@8 MP (30 fps)/4-ch@4 MP (30 fps)/8-ch@1080p (30 fps) so I shouldn't have any decoding issues with only 1-ch@4MP 20fps.
If I switch the main stream settings of all the cameras to 1080p I can live view only 1 camera on the 2x2 grid.
If I switch the main stream settings of all the cameras to 720p i can live view all the 16 cameras on the 4x4 grid.
If I reboot the NVR I do get live view from 2 the cameras on main stream and the other two display the message "not enough resource for decoding. Try switching to sub stream", and if I log in the system the two working cameras get the same error.
Finally I tried unplugging all the cameras from the NVR. When the last four where connected, 3 worked on 4MP(main stream) and 1 worked on sub-stream
Is a decoding issue? NVR issue? I am really confused and lost.
Thanks you all for your help! I am new to CCTV.
Cheers.
BTW, it's the same with h.265+
NVR
DS-7616NI-K2 / 16P
Firmware V4.74.210 build 240108
2X2 LIVE VIEW
16 IP Camera
DS-2CD1143G0-I
V5.7.20 build 230630 / V5.7.3 build 220315
CONFIG MAIN STREAM
2560*1440
full frame (20fps)
4096 kbps
h.265
CONFIG SUB-STREAM
1280*720P
20fps
800kbps
h.265
TV
FHD TV connected through HDMI
Cheers.
NVR
DS-7616NI-K2 / 16P
2X2 LIVE VIEW
16 IP Camera
DS-2CD1143G0-I
CONFIG MAIN STREAM
2560*1440
full frame (20fps)
4096 kbps
h.265
CONFIG SUB-STREAM
1280*720P
20fps
800kbps
h.265
TV
