Hi
Just upgraded from BI4 to BI5. I have a couple of issues that came up after the upgrade:
First issue and a major one: The live screen does not refresh. It shows static images for all of the cams. By static I mean the cam image is like a snapshot. If BI is minimized in Windows and then reopened, it refreshes all the cams to a recent image but they stay static. If I click to full screen on any cams all will refresh to the most recent static image when the full screen image is minimized. I am sure I tweaked something in the upgrade but I can't find it.
Second issue: For each camera all the captured clips get strung together for each cam. They are all captured and show motion, but I would much rather see separate clips for each triggered event.
I thought this would be a quick upgrade. It looked like it was painless until I noticed the problems. I have spent a couple of frustrating hours trying to figure things out.
Thanks. Any and all help is appreciated.
John
John
