I've noticed a small problem on my setup at home.
I currently have 6 x Hikvision 2132's, 1 x 2732 and 1 x 4565.
All the cameras are set to a time server.
For some reason on the live preview (note the setting on Cameras / Video during remote desktop is unrestricted), 7 of the cameras are timed perfectly.
If you click on the camera and get the full screen preview, the time is showing the seconds correctly.
On the 4565, I've noted that some of the time, the seconds are timed perfectly, then its like it hangs for maybe a second or two, then catches up. I was watching a car drive past and every now and then its like it gets hung up on a frame or two.
I also run the B.I web interface - thanks to the talented user on here.
I've noted that the 2132's which are running fine all seem to average around the high 7 to 8 FPS.
On the 4565, I note it goes from anywhere around 4 to 5 FPS.
If I use the live view on the camera web interface it seems OK?
On the camera itself, resolution is set to 3072 x 2048, constant bitrate, 15 FPS, i frame set to 15.
The box which is running BI is only sitting on around 25% CPU.
Does anyone have ideas or perhaps contact the BI helpdesk?
