little advice for a newbie please on cam selection
garny68
Aug 20, 2019
2
2
United Kingdom
hi im from uk and looking for a cctv system. way to many cams ,mpixels and lenses to choose from its driving me nuts, so after a bit a reading i see a guy called andy empire tech on here is the guy to buy from.a little more reading tell me as a newbie i should be going for a varifocal so i believe this is a good camera US $169.09 5% OFF|IPC HDW5231R ZE 2MP WDR IR Eyeball Network Camera IPC HDW5231R ZE ,free DHL shipping-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
is that the same as this
https://www.onlinesecurityproducts....-135-m-vf-50m-ir-audio-mic-micro-sd-epoe.html
not sure how old them cameras are so is there a newer model i should be
looking for or maybe a 4mp varifocal ?
advice appreciated
Hi Garny
The IPC-HDW5231R-ZE still be a very stable model here and popular.
If you want to use 4MP, you can check with IPC-T5442TM-AS fixed lens, or IPC-B5442E-ZE, motorized lens these 2 are the best new one on the market.
Andy
Reactions: garny68 and mat200
Dahua IPC-HDW4231T-Z-S4 2MP Starvis IP Dome Camera 50mIR Audio SD ePoE
advice appreciated
Hi @garny68
Do check out the cliff notes and look for the Dahua international naming convention... ( iirc they may have made some recent changes )
basically the naming convention was
IPC-HFW => IP Camera Bullet style / form factor
IPC-HDW => IP Camera Turret styel / form factor
then the number
x2xx = 2MP
x4xx = 4MP
x8xx = 8MP
So that should give you an idea of items when you're looking at comparisons and checking reviews here at ipcamtalk.
Reactions: Mike
Welcome, you’re right on target with camera and Andy. Don’t hesitate for a second to support Andy. He shipped 4 cams to me last week from Hong King to FL in 36 hours delivered. Unreal service! Load of info here, read the Wiki and invest time before money.
:welcome:
My standard welcome to the forum message.
Please read the cliff notes and other items in the wiki. The wiki is in the blue bar at the top of the page.
Read How to Secure Your Network (Don't Get Hacked!) | IP Cam Talk in the wiki also.
Quick start
1) Use Dahua starlight cameras or Hikvision darkfighter cameras or ICPT Night eye cameras (https://store.ipcamtalk.com/) if you need good low light cameras.
2) use a VPN to access home network (openVPN)
3) Do not use wifi cameras.
4) Do not use cloud storage
5) Do Not use uPNP, P2P, QR, do not open ports,
6) More megapixel is not necessarily better.
7) Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
8) Do not use reolink, ring, nest cameras (they are junk)
9) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
10) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
11) use a test mount to verify the camera mount location. My test rig: rev.2
12) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 8ft. You want to know who did it, not just what happened.
13) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
Cameras to look at
IPC-HDW2231R-ZS Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW5231-ZE Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE IPC-HFW4239T-ASE
IPC-T5442TM-AS Review IPC-T5442TM-AS-LED (Full Color, Starlight+)
IPCT-HDW5431RE-I Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
DS-2CD2325FWD-I
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A https://ipcamtalk.com/threads/review-dahua-ipc-k35a-3mp-cube-camera.37581/#post-373517
Read,study,plan before spending money ..... plan plan plan
Test do not guess
