I am trying to use a old Linksys router as an access point wifi network.
It is on a closed network with no internet access.
I set it up in 'bridge mode' and assigned a static IP address.
This is going on a internal IP Camera network - and all the cameras are on 192.168.37.xx
so I setup the linksys in BRIDGE mode as:
IP: 192.168.37.100
Default gateway: 192.168.37.1
subnet: 255.255.255.0
DNS: 8.8.8.8
I can connect to the router thru my hardwired BI system at 192.168.37.100
I can see the new wifi SSID: IPCD
I can connect to the wifi SSID from a laptop
However when I am on the Wifi I cannot connect to anything on the same LAN (IE I cannot login into any of the cams).
Also none of the IP cameras can connect to the SSID: IPCD that I created. (Amcrest cams tested so far)
Any thoughts on this issue?
IP: 192.168.37.100
DNS: 8.8.8.8
