Hoping soemone may be able to explain in words of one sylable or less.....
I currently have BI v5.x on a windows 10 PC and overall the system is working very well - especially since the change to processing subsystems - my CPU usage has dropped to 10% with 14 cameras - impressed.
I currently have a EZVIZ DB1 doorbell linked to BI and when it is triggered in BI, a http command is sent via IFTTT to turn on a light beside the door. Going via the "cloud" can take quite a while and people can be gone before the light comes on.
I have just installed Homeseer HS4 on the same PC and would like to use it to turn this light on (instead of IFTTT) - can someone please let me know what the syntax of the http command should be for this to work as I am struggling to get it to work? I do NOT have the HS3 BI plugin installed as, so far as I can tell, it should not be required for this operation.
Many thanks.
Many thanks.
