Line changed
Chura
Mar 9, 2018
174
51
Hi,
Is it possible to monitor is line is altered or something ?
I want to block rollershutter movement if something distrub its way down
You can set up detection zones on the triggers tab of the camera settings. I have one camera that over looks my AC unit, I set up a mask to not trigger based on the fan movement. Below are a couple links to some good instructional videos on setting up motion detection and hot spots.
Basic Motion detection
Zones and Hotspot
