Limit decoding unless required on the Camera->Properties->Video dialog
chaycock
Oct 23, 2015
128
31
Can someone explain (or point me to some info that does) exactly what this option does and when you would or would not want to enable it.
Also related is the "Also Bvr" check-box across from the above setting.
I checked the help page for that dialog box, but it does not mention either of these options although it does show them in the screenshot of the dialog box.
See about 3/4 of the way down here:
You can CTRL + F in the help file and literally search for limit decoding and Also BVR and learn a lot.
