Lightning strike and POE switch
International784
Apr 7, 2023
305
98
USA
I just had an EXTREMELY close lightning strike. I checked and three cameras on one switch were down. I cycled the switch twice and cams are up and running. We never lost power. Not even a flicker. Should I replace the switch? Is there likely damage to my cameras?
I just lost 2 switches and maybe the gate board in today's thunder storm
Are the switches not working at all? I unplugged mine and plugged it back it a got 2/3 cams going. A second cycle and all three are up.
the last time it happened they switches were slow to recover and failed within a couple of weeks so I just swap them out and send the old ones back for exchange
I’ll be happy if that’s my only damage. I’ve seen burnt rj45 connectors on here and all of mine look ok. Would damage to cameras or their connection be noticeable? Are your cameras still running after switch replacement?
Reactions: Valiant
cameras are good but I lost the lan connections on the pc, a small 8 port POE switch and my main 24 port switch
Wow. I’d say you had your stuff together if all cameras survived unscathed. Thanks for your response. The strike today was within 300 yards. Again, no flicker but it definitely made me check my blue iris program to see if my cameras took a hit. I saw three down and assumed the worse.
