Hi everyone,
Normally, I can make about anything work when it comes to technology. However, these IP cameras are proving to be a substantial foe. Below is a general overview of my situation. No VLAN setup yet. All but one camera is connected to a device layer switch, the NVR connected to the core layer. Right now, the 2 cameras, noted in red below, are the only ones I am unable to get access to.
So... Hi there. Hello. How are you? How is your day going? How long have you been working with IP cameras and NVR's? Can you help me get on top of this issue so I can actually use the cameras we bought? What is the best way to lock down the cameras to allow access from only the NVR and designated IP addresses within our network?
Thanks!
Thanks!
- Hikvision DS-7616NI-E2 / 16P NVR - with up to date firmware
- 12 cameras (10 of which actually work and allow connection)
- PTZ-4818X-IZ
- Unable to connect
- password recovery using the Hikvision Password Recovery tool failed
- Time's out when trying to update the IP and device info - admin password verified on all other cameras
- SADP can see the camera but am unable to modify its settings or reset the password
- default IP does not allow connection from any machine neither does the IP listed in SADP...
- HES328-TD-2.8
- DS-2CD2122FWD
- DS-2CD2122FWD-ISB
- DS-2CD2032-I
- DS-2CD2122FWD-ISB
- DS-2CD2032-I
- DS-2CD2122FWD-ISB
- DS-2CD2032-I
- DS-2CD2032-I
- DS-2CD2032-I
- DS-2CD2032-I
- PTZ-4818X-IZ
- Unable to connect
- PTZ-4818X-IZ
Welcome. Most of us here are just like you. Hang around, read up, ask questions. You will be a expert before you know it.
