ATL2059 n3wb Dec 23, 2017 5 1 Jan 15, 2018 #1 Saw this camera on ebay for just under 200. Has anyone used it / does it work with hikvision LPR software?
tangent IPCT Contributor May 12, 2016 4,641 3,996 Jan 15, 2018 #2 This is a way better camera IPC-HFW5231E-Z12E you can get it for a bit over $200
ATL2059 n3wb Dec 23, 2017 5 1 Jan 15, 2018 #3 Will it work with the hikvision lpr? Or at least to read license plates manually?
tangent IPCT Contributor May 12, 2016 4,641 3,996 Jan 15, 2018 #4 ATL2059 said: Will it work with the hikvision lpr? Or at least to read license plates manually? Click to expand... I don't know. I don't use their software. The IPC-HFW5231E-Z12E is a much better camera than the no-name junk you found on ebay. Hikvision and Dahua both make some cameras with ANPR built into the camera but they're expensive, >$400 / cam iirc. OpenALPR is a popular choice here.
ATL2059 n3wb Dec 23, 2017 5 1 Jan 16, 2018 #5 Have you used that camera for license plate reading, specifically at night?
bigredfish Known around here Sep 5, 2016 26,077 68,994 The Swamp Jan 16, 2018 #6 I have the original Z12 (not the extended epoE version, but effectively the same camera) and it works well, - as long as you can implement the Day/Night shift focus script to correct the problem it has. See this thread IPC-HFW5231E-Z12 LPR from 137 feet
