License and hardware question
BORIStheBLADE
Getting comfortable
Feb 14, 2016
792
2,156
North Texas
I have multiple Windows PCs I'd like to try a copy of Blue Iris on that have different intel GPU's. If possible how difficult is it to deactivate it on a PC then use in another?
Thanks
If you install Blue Iris without any license, it will run as a trial version for 14 days. If you uninstall after the 14 days and then reinstall it again, you can run it for another 14 days.
