Hi all,
I have just purchased a DH-IPC-HFW3866EP-AS-AUS (8MP bullet non-PTZ) with the intention of swapping the lens for a wide angle one. This is mostly because Dahua don't sell a camera (at a reasonable price) with the lens that I want (at least 170 degrees horizontal view, 90+ degrees vertical).
So my plan is to see if I can get an aftermarket lens and put it in this camera. The camera specs say it takes an M12 lens, and there are plenty of these available, however I'm not exactly sure what I'm after.
Some lenses say they are 5MP, 8MP, or 12MP - does this matter? Do I need to get a lens matching the same or more pixels than the camera sensor? Is this because of the lens clarity or something else? I assumed all lenses were analogue/optical so the MP rating wouldn't matter, so I'm not sure why they put a MP rating on the lens at all.
Lenses also seem to be for different sized sensors, even though they are all M12. Some say they are 1/2.7", or 1/3.2", etc. The Dahua camera I bought says it has a 1/2.8" sensor, so does that mean if I get a lens with a different size, I will get either a black border around the edge of the picture, or it will appear zoomed in further than the lens' viewing angle suggests?
On that note, some of the screenshots on the lens sale listings show a fisheye view (circle in the camera image with lots of black around the outside). I don't want to "lose" pixels by having so many black ones around the edge, so should I be looking for a lens that's larger than the camera's 1/2.8" and consequently with a wider viewing angle than I need, in order to both fill up the frame and get the viewing angle I'm after?
Lastly, some lenses are sold with or without an IR filter. I assume I want one without the IR filter so that IR/nightvision works, but it would be great if someone could confirm in case I am misunderstanding what this IR filter is for.
Has anyone tried swapping a lens before in their Dahua camera, and if so how did it go? It looks like with this camera I'll have to remove the thin transparent plastic window in front of the lens in order to fit a wide angle lens there (because the lens is bulbous and needs to stick out much further than the factory lens), so I'm curious how others have gone with this procedure as I imagine I'm not the first to try it.
