Lens recommendations for this location?
Elgato54
Dec 14, 2019
70
13
Arizona
I have a limited choice for mounting my front door camera.
It is as high as possible in the corner.
Would you recommend a 2.8, 3.6 or 6 for this application? Thanks
I'd use a 2.8mm dual lens camera. One lens to watch/capture faces and the other pointed down to watch for packages.
I concur with @sebastiantombs - dual lens.. also I'd move it to face level by the door, looks like you can run the cable down along the screen frame - then I would use a junction box - screw into the mortar ( easier to fix later than holes in the bricks imho )
see diagram of what i would try..
