Last minute Halloween scary sound raspberry pi project
AdySan
Aug 26, 2018
32
12
Bellevue, WA
hello folks,
I have an idea for a last minute Halloween project to scare trick or treaters. My front door camera gets triggered reliably when someone enters the front yard. I would like to send a web hook/Mqtt message to a raspberry pi (which is physically connected to a little speaker) and make it generate a random scary sound. Should be rather easy, but given the lack of time I don’t want to experiment a lot. Anyone have experience with what’s the easiest, most reliable way to do this with a BI server? I know BI supports things like IFTTT and MQTT. If there’s a simple python script someone can help me get started with I can polish it up.
TIA, Ady
hello folks,
TIA, Ady
Hook a speaker to the BI computers' audio out, setup an alert to trigger a sound to that speaker.
I was able to get this to work with this simple python script running on the pi!
Code:
#!/usr/bin/python#!/usr/bin/python
import paho.mqtt.client as mqtt
import os
MQTT_SERVER = "192.168.10.74"
MQTT_PATH = "app"
# The callback for when the client receives a CONNACK response from the server.
def on_connect(client, userdata, flags, rc):
    print("Connected with result code "+str(rc))
    # Subscribing in on_connect() means that if we lose the connection and
    # reconnect then subscriptions will be renewed.
    client.subscribe(MQTT_PATH)
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
    print(msg.topic+" "+str(msg.payload))
    os.system('mpg123 -q /home/pi/scream.mp3 &')
    # more callbacks, etc
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.connect(MQTT_SERVER, 1883, 60)
# Blocking call that processes network traffic, dispatches callbacks and
# handles reconnecting.
# Other loop*() functions are available that give a threaded interface and a
# manual interface.
client.loop_forever()
Reactions: Sapo Concho
