S shellroc2 n3wb Feb 3, 2016 24 0 Feb 5, 2016 #1 I use to get BI on my laptop, (using it away from home) but, when I tried using it recently, it didnt work. The only thing I can think of is, I was using wifi to operate my laptop.. Do you think thats the problem?
fenderman Staff member Mar 9, 2014 36,891 21,417 Feb 5, 2016 #2 How are you trying to use blue iris remotely? The webserver? If so check your external ip address.
S shellroc2 n3wb Feb 3, 2016 24 0 Feb 6, 2016 #3 thank you for getting back with me.. Not sure what I did, but, its fixed. Im thinking I had some kind of firewall applied.
