After lost ip on NVR i updated my DS-7608NI-SE / P to V.3.0.15 build 150528 to have VCA crosslining events. It was a mess with motion detection before tones of false alarms. But now just CBX region changed and 5.2.0 patched cameras are working with the NVR. The newer not region changed Chinese cameras with v 5.25 and v 5.28 shows language mismatch at NVR. All 8 cameras showing up on SADP Tool. Any help to change region permanent of this version.
these cameras are language mismatched
DS-2CD2732F V5.2.5 build 141201
DS-2CD2032 V5.2.8 build 141231
NVR DS-7608NI-SE/P08 V.3.0.15 build 150528 Encoding v1.0 build 140828
Update:
i am checked today again and interestingly my updated DS-7608NI-SE/P08 20131110BBRR44096....... V.3.0.15 build 150528 Encoding v1.0 build 140828 has different problems all NVR 4 POE ports showing language mismatch with new cameras 5.25 and 5.28 . The 4 switched POE ports, all cameras are online and working fine with cbx region changed and 5.20 patched.
If i am connect one of the working cameras to the intern POE port from NVR i am getting Network abnormal the green lights are on and yellow light searching. I just assuming there are maybe to different problems .
1. i have to region change Chinese 5.25 and 5.28 cameras
2. The NVR DS-7608NI-SE/P updated to 3.015 are included at Release note . It should be work
Thanks for any helph.
Update:
