Hi
Hope someone can help as this is driving me nuts.
I am in Australia and ordered my HIKvision NVR and cameras from China.
Everything has been good for a few months. I then wrote to HIKVision to ask which firmware update to use.
The NVR I have is the DS-7608N-E2 / 8P
The firmware they told me to apply was from the overseas site and was Baseline Firmware_NVR (76/77/86NI-E)_En_V3.3.1_build150422(new)
This seemed to be in English. When I updated it all was fine and it worked for a week until I rebooted it.
Now the web page is in Chinese however the IVMSsoftware is in English.
When I try and use the IVMS it says language mismatch.
I have found a tool on these forums called HIKtools05R1.exe and tried that however the language was already set to 1.
If I try the firmware from the webconsole it now says Failure to obtain the upgrade progress.
Is anyone able to help?
Thanks
Aron
Thanks
Aron
