- Jan 28, 2017
- 1,211
- 472
I will have this issue when trying to scrub or even playing back videos where it lags. It doesn't happen all the time.
It is very random that I don't know what could cause it - after the lag it sometimes works and other times it will just continue to be laggy.
Does anyone know what would cause this?
I use to record on older 4tb purple and then i started to record on 10tb new purple drive - no difference.
These are new videos on 10tb not older ones (just recorded)
when I reset blue iris it sometimes works but then eventually does the same thing. It feels random to when it will happen so I don't know if it is the computer or BI causing it.
this happens with all updates - i am on 5.4.9.18 because when i switch to the new updates the padding on the camera name (color coded part) becomes too big. A separate issue I need to look into. So I stayed at 5.4.9.18 for now
