Known Cams with disable LED Option?
jasoncmt24
Feb 7, 2015
27
Buying a new cam soon. What cams have the option to shut off the IR in the software?
If you mean disable the ir while keeping it in night mode so that the camera can pick up external IR then hikvision can do this...not sure about dahua..i dont think so though...if you just want to disable IR without night mode, almost any cam can do this by setting it to day mode only.
