Keyframe Interval (GOP) ??
Stev Wolf
May 7, 2017
95
7
I have tried to read up on Keyframe Interval which I think ? is the I-frame
I'm confused despite reading many posts and web sites. It appears the setting is somewhat based on needs and equipment.
The question I have in part is does a low number like 30 use less cpu. The default seems to be 300 . I'm unclear which direction uses less CPU.
Second question.
Also, my reading tells me that on windows 7 running BI as a service is not as efficient for CPU usage.
I like running as a service, my reading seems to indicate that some of the resources to help lowering CPU usage are not available , or as optimized to Windows 7 if run as a service.
Can anyone tell me if this is true?
Thank you very much for you'all advice.
