- Jul 31, 2015
- 167
- 12
Hi,
The last couple of weeks my Surface 3 started rebooting a couple of times a day. I know I shouldn't be using this for my server, an i7 is on my wish list. I don't think my Surface has gotten too hot, I typically run Blue Iris and Tools and two cams at under 25% CPU usage. Four cams bring it up to maybe 35%. I actually did a Windows reset last weekend that didn't seem to help. Then I went to power management and disabled the power off button because it's mentioned in the error log. I'm running BI D2D on all cams and using Intel HW acceleration about 5fps at 1280x720.
I found this but it just made me more confused. https://support.microsoft.com/en-us/kb/2028504
I plan on switching BI to my backup (old) computer this weekend to see if the Surface still does it without BI and Tools running.
Any help would be appreciated, Thanks
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 3/8/2016 1:38:55 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-73JAAPO
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>3</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2016-03-08T20:38:55.904447500Z" />
<EventRecordID>3237</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-73JAAPO</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">159</Data>
<Data Name="BugcheckParameter1">0x3</Data>
<Data Name="BugcheckParameter2">0xffffe000d628c840</Data>
<Data Name="BugcheckParameter3">0xffffd001cf306ce0</Data>
<Data Name="BugcheckParameter4">0xffffe000decf1d80</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
</EventData>
</Event>
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
