Todd Schmidt Getting the hang of it May 17, 2019 119 50 Massachusetts Oct 10, 2019 #1 Why does this symbol keep showing up? Dropbox - IMG_1046.PNG - Simplify your life
Todd Schmidt Getting the hang of it May 17, 2019 119 50 Massachusetts Oct 10, 2019 #2 Well emojis don’t work. It’s the red circle with slash through it.
pinko Known around here May 26, 2017 385 623 Australia Oct 10, 2019 #3 Not sure what symbol you mean. If you mean the whole page you can change this via the settings (cog). Scroll down and change After login, show to the desired setting.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,336 48,154 Alabama Oct 10, 2019 #4 If it keeps showing in the app, I think it means the schedule has been overridden, either by another setting or manually, back on the BI server. Reactions: looney2ns
Todd Schmidt Getting the hang of it May 17, 2019 119 50 Massachusetts Oct 10, 2019 #5 TonyR said: If it keeps showing in the app, I think it means the schedule has been overridden, either by another setting or manually, back on the BI server. Click to expand... Hmm... wonder what setting? It was working fine when I first started it and I haven’t changed anything. It just started with the last update to BI.
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,336 48,154 Alabama Oct 10, 2019 #6 Todd Schmidt said: Hmm... wonder what setting? It was working fine when I first started it and I haven’t changed anything. It just started with the last update to BI. Click to expand... Possible errant mouse click or touchscreen tap? Reactions: looney2ns
Todd Schmidt Getting the hang of it May 17, 2019 119 50 Massachusetts Oct 10, 2019 #7 TonyR said: Possible errant mouse click or touchscreen tap? Click to expand... Guess it’s time to go back and recheck all my user settings. Reactions: TonyR
