Hi,
I am looking to install 6 to 7 Hikvision Cameras and connect it to a HIKVISION DS-7608NI-E2/8P 8CH PoE NVR with a WD Purple 4TB to 6TB drive
4 HIKVISION DS-2cd2632f-is 3MP Bullet Cameras
3 HIKVISION DS-2CD2132F-I 2.8MM IR 3MP Dome Camera
I've been reading several of the threads on this site along with browsing the web and my biggest concern is the lack of support when issues arise
NVR issues, shutdowns, crashes, Camera Stuttering are just some of the few common issues I've read.
I'm looking for advice on where or where not to by my equipment for tech support reasons. I was told to make sure all products are HIKVISION USA Not Hikvision "International (which I assume means China)" but on Amazon.com it doesn't always specify
Any caveats to look out for with this particular NVR or these camera choices?
Any issues with build quality where you get a bad unit that just won't cooperate?
Any issues that would make the DS-7608 a bad choice for a 7 camera setup?
I've seen the youtube clips on the DS-2CD2132F-I and 2cd2632f-is; the price point and performance is decent, but my concern is are there any configuration issues that I should look out for with the DS-7608 NVR
Thanks for your feedback, and thank you for this forum.
Corey
Corey
