Just installed first 2332 - Where do I set the Camera name?
105437
BIT Beta Team
Jun 8, 2015
2,196
1,085
I'd like to change it from Camera 1 to Driveway Cam. Thanks
attachment.php
Sorry I can't answer the question but excellent picture quality and good view of the drive and yard! Is that 2332 with a 4mm or 2.8 mm lens? and is the camera mounted to the overhang or the side of the house?
Thanks @corkangel76! I appreciate it!
@Rudyjr... this cam is mounted in an overhang. See picture... Also, it's a 4mm camera.
attachment.php
That looks excellent! Where else are you putting cameras ? I have a ranch and have been struggling with camera placement to cover the doors and other areas.
I also like your Life is Good sign! That is my 84 year old fathers favorite saying!
@Rudyjr... got one more camera to install to capture the patio and back yard. The patio cam will show both doors in back, the patio door and the other door in our covered porch. Yep, "Life is Good"!
Just got the second camera installed.
attachment.php
attachment.php
I see you have the camera named and the picture looks fantastic! I assume this is a 4mm as well? I see you are working on viewing them on a Mac laptop. I am going to be faced with the same problems as i am using an IMac desktop. Are you using an NVR as well?
@Rudyjr... Yep, it's a 4mm as well. I'm not using an NVR but decided to use Sighthound and save the recordings to an external hard drive connected to the MacBook running Sighthound. I'm glad I went with 4mm because it gives me the field of view I was looking for. 2.8 would have been okay but everything would have been a little smaller.
@Del Boy... Thanks, I'm very pleased with the 4mm lens. Covers exactly what I wanted and as you said, doesn't distort things as much.
