Just for fun: Stream your dashcam to BlueIris
silencery
Pulling my weight
Oct 6, 2015
241
177
This isn't really a practical setup, but just wanted to share a quick project. Grain of salt, this requires quite a bit of infrastructure so it's not for everyone, but I figured I'd share anyway. There are a lot of ways to do this, but I did it with mostly things I had lying around. Here's a screenshot:
TOPOLOGY OVERVIEW
Since BI supports RTSP streams, I assumed adding a dashcam with RTSP would work. I knew in advance BI would fail gracefully with RTSP streams cutting in/out, so I wanted to see if I could get everything working by simply building a remote transparent bridge. To do so, I decided to enable a wireguard VPN connection to my car. The dashcam would just be a remote client which the BI server at home would record whenever it came online.
PARTS USED
  1. Dashcam: Viofo A119 mini2 (must be on at least firmware V2.1_20241010 to enable wifi station mode)
  2. Mini Router: GL.iNet - GL-AR300M16 (to share internet to dashcam and enable VPN route)
  3. Internet: Android Phone with hotspot routine
SETUP
  • Car LAN configuration:
    • Create a routine on phone to turn on mobile hotspot sharing in the car. This is simple to do with android routines; I assume iOS is similar.
    • The AR300M is great since it's powered by USB, so the easiest thing to do is to get a cigarette USB adapter and just have the router turn on whenever the car's ACC is on. In my case, I just threw the router into the center console since there's a cigarette plug there.
    • Set the AR300M to repeater mode in order for it to access internet from the mobile hotspot and share its connection to the dashcam.
    • Set a static DHCP assignment (e.g. 192.168.8.10) for the dashcam in the AR300M mini router, since the dashcam's limited config doesn't allow you to set static IPs. If you don't do so, the dashcam's address may change at each boot and the BI server won't be able to route to it.
  • Camera Setup:
    • I lucked out and my dashcam supports wifi station mode (with the latest firmware). This means I'm able to have it connect to the AR300M as a normal wifi client.
    • However, one major hiccup is that wifi needs to be turned on each time the dashcam starts.
  • VPN tunneling from car to home network:
    • This is the meat of the project. The idea is to setup an IP tunnel which turns on whenever the car is in use. Once the car turns on, the tunnel is established. Once BI is able to see the connection, the stream will automatically start recording.
    • Create a VPN tunnel to your BI site (home server). I already run wireguard, so that's what I went with, but this would work with openVPN too.
    • The AR300M16 is perfect for this because it supports both openVPN and wireguard out of the box. Setting up VPN client tunneling on the AR300M16 is pretty trivial nowadays since it even lets you upload config files.
    • For DNS reasons, I changed my phone's car routine to disable wifi on my phone before turning on the hotspot. Otherwise, the wireguard connection would try to connect to the LAN address for the VPN server.
  • BI Server Setup:
    • The final step is to ensure the BI server can see the camera through the IP tunnel. In my case, my BI server isn't normally part of the VPN. Because the dashcam is on its own subnet (192.168.8.0/24), I manually created a routing table entry on the BI server to route 192.168.8.0 traffic through the VPN gateway (192.168.3.20). In windows, the command looks something like this:
      Code:
      route -P add 192.168.8.0 MASK 255.255.255.0 192.168.3.20
    • After verifying I can reach the camera through the VPN tunnel, I added the camera into BI as a normal RTSP camera: RTSP:/192.168.8.10
SUMMARY
This actually worked out pretty well, but it's not necessarily practical. More of just a fun thing to try out.
The friction points right now are: A) the need to manually turn on wifi on the dashcam and B) relatively low performance for high data consumption cost.
For the first problem, this can likely be resolved pretty easily. I would have to research other types of dashcams which support wifi station mode on startup.
As for the second problem, the RTSP stream is limited to 480p and data consumption is roughly 600MB/hour of driving (about 1.3Mbps). Of course, an unlimited data plan would be recommended for this. I haven't yet found a way to see if the RTSP stream can be tuned, but perhaps there are ways to improve here as well.
EDIT
After getting in touch with Viofo to ask if they could enable wifi station mode when the camera boots up, they amazingly responded with a new firmware update. Very cool! This means the process starts up hands-free now.
TOPOLOGY OVERVIEW
PARTS USED
SETUP
  • Camera Setup:
  • BI Server Setup:
      Code:
      route add 192.168.8.0 MASK 255.255.255.0 192.168.3.20
SUMMARY
As for the second problem, the RTSP stream is limited to 480p and data consumption is approximately 600MB/hour of driving. Of course, an unlimited data plan would be recommended for this. I haven't yet found a way to see if the RTSP stream can be tuned, but perhaps there are ways to improve here as well.
TOPOLOGY OVERVIEW
PARTS USED
SETUP
  • Camera Setup:
  • BI Server Setup:
      Code:
SUMMARY
awesome, i am also using the same model. i use mini camera 2cd2d25g1 and inet gl mt300n for vpn use, for mobile data i use dcom 4g huawei, rtsp quality reaches full hd with 60fps and h265+ compression standard saves data and bandwidth. however the anti-backlight feature will make the camera only 30fps and i can not see the license plate at night
Reactions: silencery
Thanks for the info. That's a good point. I may try out some other types of cameras.
I still haven't found a solution for turning on wifi on the dashcam manually, so that part is an annoyance. Most dashcams I'm seeing disable wifi in order to save power and cpu cycles since they typically don't need to be connected all the time.
The hikvision looks like a great option. Night-time license plates can be a problem, yes, but that's a hard thing to capture for many dashcams too. I love that it supports alternative codecs for RSTP. Do you know what the bitrate is?
About 4000-6000Kb/s
i'm trying to find a 2-4k, 60fps and compact camera but it seems there is no ip camera that supports such resolution and frame rate
Makes sense. I wouldn't expect there to be a large market for those features in the IP or POE based camera options. Especially high framerate.
I'll keep my eyes open and report back if I happen to see any suitable cameras.
Reactions: nnthoi1994.1
Great news. Just wanted to report back that viofo was able to provide a firmware update for the A119 MINI 2 which enables wifi station mode on boot after I got in touch with them.
Awesome support!
This means problem A above is resolved for this setup.
Reactions: Oneup and looney2ns
Awesome support!
maybe i will buy this dashcam, 2k 60fps resolution is awesome. please tell me what resolution and frame rate the rtsp stream has, i searched everywhere but no information, thank you
The RTSP stream is basic 480p.
There might be a way to access higher res options through URL parameters, but I haven't tried yet.
TOPOLOGY OVERVIEW
PARTS USED
SETUP
  • Camera Setup:
  • BI Server Setup:
      Code:
SUMMARY
EDIT
This is super awesome. I've been wanting to setup vehicle recording and looking for dashcams that support RTSP specifically. I was planning on installing a lightweight SBC in the glovebox or somewhere more secure and running a lighter NVR to record everything locally, but then also have the option to access it remotely. With the way everything is moving towards a subscription model, I wish more manufacturers would support and advertise when their products support RTSP. I also hadn't thought that wifi enabled dashcams may not support station mode natively. It does make sense that their default would be to act as the host / AP mode since that is how most people would use them, but ideally they should be capable of acting as a client in station mode as well like you mentioned in your post.
Reactions: Flintstone61
Thanks for information!
Just be careful you don't fall foul of fair usage clauses. Whilst most "unlimited" data plans are unlimited in theory. Most contain a fair usage clause whereby if you use really large amounts they either cap your usage, add additional charges or cancel your contract.
