No, Blue iris is not needed. When you are frustrated with smartpss come back for more advice. This way you will appreciate blue iris more.So I'll be doing 4x Dahua cameras at max. I believe their own software is SmartPSS?
For a simple 4x 4MP setup, is BlueIris really necessary? I don't really need fancy features like automation integration. Just need 24/7 recording on 2x 3TB WD Red drives. 2 cams per drive at most with 4 cams.
If all you really need is to record 24/7 then use an nvr.
No one already has the parts...even if you did, you can simply sell them. A standalone NVR will be more efficient.I already had the parts so already built the machine! No point in buying NVR! Besides this thing is pretty good specs wise for a 4 cam machine (8th gen i3 4 core, 12GB DDR4, 120 SSD, seasonic PSU, 2x 3TB WD Reds, on a 1500 VA UPS)
I'd love to hear what you feel is wrong with smartpss.
Sure some of us do! I've had tons of stuff from decommissioned mining rigs and other things. NVR might be more efficient yes but this thing has quick sync (efficient) and selling tons of parts is already a hassle.No one already has the parts...even if you did, you can simply sell them. A standalone NVR will be more efficient.
Nothing is wrong with smartpss, that is why I am recommending you use it, you need to experience this for yourself. Its the best and only way.
BI has a 15 day trial I highly recommend using. Try it side by side with any alternative option to see what you like best. If you want lots of options and flexibility that you can tweak and refine you will most likely love BI and buy it long before the 15 day trial is up.
