Now I just tried to get the first one working before adding in more.
The ipcam connect to a POE+ switch via Cat5e cable; the BI5 PC and the cam are connected into the same POE+ switch.
Asus router RT-RC68U can identify the ip 192.168.1.108 as "Dahua Tech" being the client name.
BI5 installed on a HP EliteDesk i7-6700 Windows 10 Pro PC, its ip 192.168.1.71
The cam and the BI5 PC are in the same network - SUBNET 255.255.255.0 GATEWAY 255.255.255.1
I can ping 1.108 successfully
When adding camera 1, I just typed in the static Ip of the cam (192.168.1.108), then find/inspect, use the default values for anything else.
Got the following error:
Cam1: no signal
Error:80002746 (socket error: 10054) 0
Please help as i am a newbie here.
Cam1: no signal
