S silvertonesx24 n3wb May 6, 2025 20 1 Chicago Sunday at 2:53 PM #1 I would like the on-device LPR to send an ONVIF trigger with plate info to Blue Iris. Does anyone have this set up like this? Or if I want Blue Iris to really use LPC, do I need to have Blue iris do the Licence plate detection?
wittaj IPCT Contributor Apr 28, 2019 31,219 59,852 USA Sunday at 3:11 PM #2 Unfortunately the plate info is in a proprietary format and cannot be sent to BI. The IVS rule will trigger BI, but that it is. I have an SD card in the camera for redundancy.
S silvertonesx24 n3wb May 6, 2025 20 1 Chicago Monday at 8:35 AM #3 wittaj said: Unfortunately the plate info is in a proprietary format and cannot be sent to BI. The IVS rule will trigger BI, but that it is. I have an SD card in the camera for redundancy. Click to expand... Is CP.AI the main way of doing ALPR in Blue Iris then?
wittaj IPCT Contributor Apr 28, 2019 31,219 59,852 USA Monday at 10:12 AM #4 That is correct. Or Plate Recognizer if under the free amount of lookups.
B BillyButler n3wb Jun 11, 2025 1 0 Philippines Yesterday at 8:31 AM #5 Thanks, I also want to know it.
