P pburgh Getting the hang of it Aug 1, 2016 106 15 Nov 27, 2017 #1 Can someone point me in the right direction for a junction box to use with IPC-HFW4431R-Z? Thank you
P pburgh Getting the hang of it Aug 1, 2016 106 15 Nov 27, 2017 #2 Would the PFA122 or PFA135 work with the IPC-HFW4431R-Z camera? Last edited: Nov 27, 2017
PatPend Pulling my weight Jul 10, 2016 160 195 Nov 27, 2017 #3 Do you or someone you know have a 3D printer? Dome Camera Junction Box by rssalerno Last edited: Nov 27, 2017 Reactions: RJF
P pburgh Getting the hang of it Aug 1, 2016 106 15 Nov 27, 2017 #4 That's an interesting idea, but no... I don't know anyone that could print that shape for less than I'd pay for the boxes on eBay.
looney2ns IPCT Contributor Sep 25, 2016 16,321 24,226 Evansville, In. USA Nov 28, 2017 #6 PFA121 - Dahua Technology Reactions: pburgh
T t84a Getting the hang of it Oct 10, 2014 204 40 Maryland Nov 28, 2017 #7 I use www.treatstock.com. Using the above model, it's about $10-$15 shipped per unit.
P pburgh Getting the hang of it Aug 1, 2016 106 15 Dec 11, 2017 #8 Thanks. I'll try the PFA121. I also picked up a PFA135 (photo attached). It works, but there's not a ton of room for coiling up the wires inside. Attachments IMG_0832[1].JPG 1.7 MB · Views: 36
mat200 IPCT Contributor Jan 17, 2017 16,139 27,107 Dec 11, 2017 #9 pburgh said: Thanks. I'll try the PFA121. I also picked up a PFA135 (photo attached). It works, but there's not a ton of room for coiling up the wires inside. Click to expand... FYI - PFA121 looks like it works for bullets which has more square base and 4 screw points...perhaps the PFA122 works better,
P pburgh Getting the hang of it Aug 1, 2016 106 15 Jan 24, 2018 #10 Yes it is tight, but it is possible to get everything in there. Reactions: mat200
