- Jul 31, 2017
- 8
- 1
Hey all,
Trying to integrate BlueIris with my HomeAssistant instance. Really just setting profiles based on home or not is all I want to do.
So I found this: GitHub - magapp/blueiriscmd: Python cmd tool that talk with Blue Iris Camera surveillance software
However it doesn't work at all, even after converting to python3 I still get errors about invalid logins.
So I figured I would try to use curl and manually hit the interface, using the documentation here: JSON interface
But that also doesn't work. There are no actual examples, and the closest I can get is:
{"result":"fail","session":"xxxx","data":{"reason":"missing response"}}
So I guess my question is, how does one actually use the JSON API? And is there some useful documentation somewhere?
Thanks!
Dan
Thanks!
Dan
