SouthernYankee
When BI is recording a video stream if configured correctly it will not do much processing, It just takes the video an put it on the disk. If you are doing motion detection it will decode and process some of the stream (limit decoding unless required) . On play back it must decode the complete stream.
So I agree with looney2ns you are over loading the PC.
Do you have the jerky problem on the other 2MP camera.
Did you try setting the 5mp camera to a 1920x1080 setting and see what happens.
On the NVR i have seen NVRs that say the can do 4k, but when you look at them close it is only on one channel at a low frame rate.
I have a good PC that I picked up on EBay for less than $200 (i7-4790 HP elitedesk tower) windows 10 pro. I added an SSD (240GB) and a 4 TB purple drive (about $150)
