Jerky Playback in UI3 and Console - Export Fine though
IReallyLikePizza2
2,528
5,927
Houston
Anyone had this issue?
I can't say I've noticed it really being an issue, but I was going through some clips and noticed there is a very consistent pause every X seconds. No changes have been made apart from fixing the audio issue with pre-buffer and enabling audio on the clones
Tried turning off HA, no change. Tried increasing the frame rate in the window, no change. UI3 and Console show the same thing, but the export is fine. My last fix would be to try a different iGPU driver, but boy do I not want to mess with it
Hopefully this video helps
And here is that last clip exported, completely fine (15fps, so not buttery smooth of course!)
