- Dec 27, 2016
- 36
- 7
Hi everbody.
I'm new here but I'm trying to read alot to get informtion about cameras and nvr, not being native english speaker makes it sometimes hard to understand all the technical stuff here though.
I have some questions, and more to come, about IVS.
I do searched the forum for answers but I'm still not sure how IVS is implemented, in software of the cameras or external software used by computers or NVRs.
First can IVS be built in a camera, working without any external hardware, like an NVR or a computer?
Meaning you can get email pushed by the camera when an alarm is triggered even though an NVR or a computer are not connected to the camera.
I see that motion detection on my camera working that way but I haven't got the IVS working the same way or not working at all.
Anyway, my conclusion is my camera doesn't have IVS built in, if that is possible, this is my camera:
Dahua H2.65 IPC-HDW4431C-A
Dahua H2.65 IPC HDW4431C A Built in MIC HD 4MP IR 30m network IP Camera security cctv Dome Camera Support POE HDW4431C A-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
It doesn't say anything about IVS but it says:
"Intelligent analysis
Support regional intrusion; mix-front invasion; legacy/disappearing scene change; audio anomaly detection; face detection; wander testing staff gathered; fast-moving vehicles detection and alarm, support multiple triggered joint action; support filtering"
I have tried to use external software to implement IVS, like smartPSS and NACL web plugin for Chrome but I haven't got it working. I don't have an NVR yet so I thought my laptop could work as an NVR with the right software, for the moment.
In smartPSS on my laptop I can draw lines and save it but nothing triggers it and it doesn't work.
In NACL web plugin no lines are drawn in the picture in any of the different IVS triggers.
Clicking "Draw Rule" nothing happens in the picture like it does in smartPSS, no lines are visible at all.
I also got a feeling that the NACL web plugin is superior the smartPSS software and overide it but that is just a feeling.
For example if I check the box, motion detection, (enable), in NACL web plugin, it works without the computer on, the camera push a picture to my email.
Using SmartPSS, adding a smart detection alarm, nothing happens if I haven't enabled motion detection it in NACL web plugin first, if doing that, I get alarm in smartPSS.
Now back to main question, have do I implement IVS, is my camera compatible with IVS, am I using the wrong software or will it work with a Dahua NVR, I don't get it.
Please help me understand.
