I was playing around with IVS & tripwires using Web V5 for my IPC-T5442T-ZE. Only minor changes to an existing set of rules. Well, I must have broke something and I have spent hours trying to find a solution. Any trip wire event triggers fine, BI processes it passing onto CodeProject.AI which will almost always return "Nothing found" for a very obvious object (i.e car, person) streaking across the screen. Sometimes AI returns "Occupied" but never identifies the actual object. Before I was playing around with these tripwires this all worked fine without any obvious fails. Hre is what I tried to find and fix this problem:
I removed/re-install Codeproject on either remote or local server.
Rebooted the camera, BI pc and AI servers
I disabled all existing tripwires and created one new one (both directions). It made no difference.
In place of the trip wires I created an intrusion area right around where the tripwires are. Same problem but less frequent (sometimes it actually gets it right).
I disabled ONVIF and enabled BI motion Sensor. All is good. No issues with AI.
All other cameras(all using BI motion sensor) on my system have no issues with AI
Bottom line is I can not tell whether this is a camera/IVS problem or BI problem. Below is a screen shot of IVS rules. At the bottom of the screen is an intrusion area which appears to work but I have only started to look into this.
I feel I have exhausted all my options and am at a loss on where to look nextt
