I have two cameras that don't detect motion using IVS. One is an Empiretech 4KT and the other is the T-180. All my other 4K T cams function just fine using IVS. I have everything set up with these two cameras exactly the same way as the others that work just fine. Settings are identical in both the camera GUI as well as in Blue Iris. I am using the Pushover app and use the basic email function to get alerts. I can right on the cameras in both Blue Iris as well as UI3 and select "trigger now" and I get the Pushover alert just fine. But, if I walk in front of these two cameras I get nothing. In the camera status it shows zero triggers and zero motion. I have tried doing a factory reset as well as deleting the camera from Blue Iris and having BI re-discover the cameras. Nothing has worked.
I wanted to add that I have tried regular motion detection in Blue Iris (No IVS) and it works just fine.
Any ideas?
Any ideas?
