Hello guys,
I have a problem as you have probably guessed
I have 2 wifi Dahua cameras IPC-HDBW1435E-W-S2 and an Dahua wiz sense 8 channel NVR NVR2108-I.
I am using NVR's AI (ivs) for motiom recordings but ibhave an issue. I don't know how to configure it so it will start recording when intrusion is triggered and stop recording when the object leaves the intrusion area. All i get are around 10 second recording which start a few seconds before anything happens, and end before the object leaves the area. What am i doing wrong?
Also when i get the notification on the dmss app i can only watch the recording, but cannot browse through them. It's annoying.
Everywhere i look for answers i see i should turn on the smart plan. But in my case when i click on the smart plan it shows the red disconnected sign and i can't do anything. You have any thoughts on that maybe?
Hard reset the nvr and try again?
Thanks for the help guys
