I've had a 5442 turret (IPC-HDW5442TM-ASE) in my barn for a couple of years now and it has been working fine. IVS alerts were reliable, with the occasional bug or spider triggering it. It dawned on me the other day that I had not received a false alarm in a while. No stray cat, bug, spider, etc. I thought it was odd since I would normally get a false alert once a week or so. So I went out there to test it. I had not been in my barn since probably around late December. Sure enough, IVS is not working at all. Nothing has changed on my end other than the occasional BI updates. All settings were the same. I tried a reset of the BI service, reboot of the camera, reboot of all switches, etc. I am able to manually sent the alert via the lightning bolt test icon in the alerts tab. Tried clearing my IVS intrusion box and redrawing it. I made sure IVS is selected in the Smart Plan tab. I made sure Onvif is turned on in the camera gui. I do not have an SD card in this camera so I cannot see if the camera is actually recording anything locally. When I tried to re add the camera in BI I noticed something strange. When I use find/inspect, all of my other cameras show up as Generic/Onvif and it populates the mainstream tab. Then I am able to click the substream tab and select the substream. With this camera, however, there is just the forward slash and no option to select anything. The camera streams fine in BI but am getting no substream.
However, when I select the substream dropdown menu, I can only select 'default'. I then save and test, but am finding that my substreams are not working. I then manually entered /cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif in the main parameter section and /cam/realmonitor?channel=1&subtype=1&unicast=true&proto=Onvif in the sub parameter section. This results in no signal and error: BARN: No signal Error: 8000007a (Check Port/User/Password) 0
I suspected an issue with the camera itself, so I tired a camera default with no success. Then tried a firmware update to System VersionV2.840.15OG00D.0.R, Build Date: 2022-08-18 , making sure to do default before and after the update. Still no change. I can get substreams to work by manually selecting Dahua as the make and filling in the appropriate parameters, but I suspect that it's not pulling something Onvif related from the camera. During Find/inspect, it seems odd that this is the result I get:
Any ideas of what I could be missing? I compared all settings with my other cameras, and nothing else has changed, and all other cameras are alerting IVS events fine. I've been messing with it for a couple of days and have run out of ideas.
