Hello, I am on Yosemite, and have the latest versions installed for the OSX system and all browsers.
When I use Safari to connect directly to a camera via its IP address, I can clearly see the live feed, and setup anything I want on the camera, this works great and as expected.
I have installed the IVMS4200 server, streaming server and client on a Windows 7 PC.
Everything is going great there, and all features are working as expected.
All the setup is done and working properly.
However, if I try to connect to the IVMS4200 client web address, (Enabled in the system configuration), I have issues.
When I put the IP address of the client software in Safari/Chrome/Firefox in OSX Yosemite, it will connect me fine to the client installation that is running on the server and prompt me for the login.
I will see the IVMS4200 login page, and I can successfully login there, using my Admin login.
The problem is that after login, in the middle of the page for the live View, it says:
Please click here to download and install the plug-in. Close the browser when installing the plug-in.
When I try to click on the link, nothing happens, the link does not download or open anything else at all. I have tried everything I can think of, disabled popup blockers, etc... Nothing works.
If I try to go to a different tab, system configuration for example, I cannot select the folders to save the local captures and videos...
It appears that if I connect straight to the camera from Safari, everything works as expected.
But if I try to connect to the IVMS4200 (2.3.13) client, through the web interface I can login, but cannot do anything from there other than going to the different tabs.
I have downloaded and installed manually the WebVideoPlugin.pkg, but that did not work either...
Thank you for your help.
CTF.
CTF.
