- Sep 9, 2015
- 2
- 0
Hi Everyone
My config are as follows
NVR DS-7616-NI-Se/p with 8 cams
I have successfully forwarded the requested ports and i can access the NVR externally with the address http://abcxxxnoip.me
but when i configure it with Ivms 4500 and selecting Ip/domain and using address as abcxxxnoip.me and proper 8000 port it only says connection failed
But if i use the external IP address instead of abcxxxnoip.me it works fine.
I can't use the IP address indefinitely as it is not a static one and thus the reason to use noip.com
I have tried also another settings and register the DDNS www.hik-online.com but it will always failed when trying to save the settings
Some help will be much appreciated
