Hi All
First time install and playing with this software on PCNVR (I had BlueIris but it pegged the CPU to 100% and would always crash)
I downloaded iVMS and was easy enough to setup but it does not record on triggered events - I can see that the events are triggered by movement in the correct areas but no video files?
If I hit manual record it all works fine, video files in the correct directory, unfortunately the system only has a 500Gb HDD and this will get used pretty quickly if it is set to continuous record.
Looked in the User Manual and it talks about a Storage server - is this needed to get these events to record?
Any tips appreciated!
- System is 3x DS-2CD3345-I (20fps 1080) and an older computer (Windows 7) running the software.
