I have two of the following types of Dahua POE Cameras
Device Type IPC-HDBW4433R-ZS
System Version 2.621.0000.28.R, Build Date: 2017-09-12
Both cameras have Ethernet cables (100 ft is longest) run back to the POE Switch.
1 camera has been ROCK SOLID for 6 years now. Never an issue. Its always on and accessible
The second camera, or camera location, has been a nightmare and hoping someone might have an idea of what is going on. I have had two of the same camera types up there as I thought the first one was bad, but the second does the same thing. The camera just drops offline and doesnt come back sometimes for weeks / months. Its really hard to get to the camera due to needing a high ladder, so only really accessible in summer. No rhyme or reason. Some other details
When its on, its fine....its just off most of the time......
Anything I can check on the camera when its on?
I have the same camera on the other side of my house that has same weather protector on it and is in teh same elements outside and its NEVER not worked. I replaced everything on the second side and still have same issues.
- The first camera ended up having corrosion in the ethernet port on the camera.
- Second camera that is there now I made sure the weather protector is on like fort knox and still the camera will come on for a few days then disappear for a long while.
- I have replaced the 100 ft cat 6 cable twice. The first two times were cables I made, the third time (now) there is a pre-bought 100 ft outdoor cat 6 cable run to it.
