Good morning,
I am setting up 2 IPC-HDW5231R-ZE cameras. I am using Blue Iris and the config tool, tp-link 4 port poe switch TL-SG1005P. I was able to get 1 camera up and running and used the DHCP setting to change the IP address in the config tool. The other camera I had selected DELETE on accidently and now I am unable to get it to show up.
If I plug the camera that wont show in config tool in, change the ipv4 address to 192.168.1.5 for example, I can ping it in command prompt so I believe it is getting a signal. I just don't know how to make it appear so I can change the IP and get it to work. When I go to 192.168.1.108 with that camera I can't get anything to show.
I also tried to plug both cameras into the POE switch and neither would show in blue iris. I unplugged the one that doesn't show up and then the other one worked in blue iris.
Any ideas on what I need to do to fix this? Hopefully I am just missing something easy here.
Thanks!
Thanks!
