For context, I am prototyping a python script to automate adding users to cameras, setting permissions, etc..
I am using the POST
From the successful web interface requests for adding a user to the camera and from referencing the API spec, I can see that the cURL command has the following body:
I am replicating this as closely as possible in my python script:
But receiving this response:
From my understanding, this is an error raised before any decryption is done on the sensitive data. I believe I have matched the XML structure, so not sure how to debug here.
I am using the POST
/ISAPI/Security/users endpoint with query params ?security=1&iv=b549f9750d5..... Full url string as http://<CAMERA_IP>/ISAPI/Security/users?security=1&iv=b549f9750d5...., depending on iv and camera IP.From the successful web interface requests for adding a user to the camera and from referencing the API spec, I can see that the cURL command has the following body:
Code:
<?xml version="1.0" encoding="UTF-8"?><User><id>0</id><userName>9ef1acdbd753229c178c6f80a526a43e</userName><loginPassword>e7ffa70bc017b918b089da8558533a68</loginPassword><password>e7ffa70bc017b918b089da8558533a68</password><bondIpList><bondIp><id>1</id><ipAddress>0.0.0.0</ipAddress><ipv6Address>::</ipv6Address></bondIp></bondIpList><macAddress/><userLevel>Viewer</userLevel><attribute><inherent>false</inherent></attribute></User>
Code:
user = (f'<?xml version="1.0" encoding="UTF-8"?>'
f'<User>'
f'<id>0</id>'
f'<userName>{encrypted_username.hex()}</userName>'
f'<loginPassword>{encrypted_login_password.hex()}</loginPassword>'
f'<password>{encrypted_password.hex()}</password>'
f'<bondIpList>'
f'<bondIp>'
f'<id>1</id>'
f'<ipAddress>0.0.0.0</ipAddress>'
f'<ipv6Address>::</ipv6Address>'
f'</bondIp>'
f'</bondIpList>'
f'<macAddress/>'
f'<userLevel>{user_level}</userLevel>'
f'<attribute>'
f'<inherent>false</inherent>'
f'</attribute>'
f'</User>')
Code:
<requestURL></requestURL>
<statusCode>6</statusCode>
<statusString>Invalid XML Content</statusString>
<subStatusCode>badParameters</subStatusCode>
