I've checked in the hikvision camera settings and it is set at 15 fps, but in blue iris the main stream doesn't get above 6fps but the sub stream is nearly always 15fpsThe cam setting looks right.
As sebastian said above, BI just shows how the camera is set. You don't/can't change that there.
You should see the same in BI now after the change on the cam.
do you mean my computer is set to wifi not ethernetDoes it also have this frame rate issue during the day? Very slow shutter speeds can cause frame rate to be reduced, but I would not expect that to happen only on the main stream while the sub streams achieves the full 15 FPS....
I notice the bit rate that Blue Iris was receiving is less than half of what the camera is configured for (8192 Kbps in camera should be about 1024 kB/s in Blue Iris after unit conversion). Since you have Variable bit rate quality set to Highest, I would expect the bit rate to be higher. Is there any wifi involved to get the video stream between your camera and Blue Iris?
posted in the first postWas going to say the same. Only thing I can think is that VBS is causing it to be less than as set.
Might also post a screen capture of the camera tab from the BI status screen.
