The ongoing quest to get BI running with adequate performance continues.
I moved the BI software from my laptop to an old desktop running Windows XP, and as I feared, that computer is just too slow. The CPU runs at about 70-80 percent, and when Teamviewer is used to remote into the desktop, it goes to 100 percent.
I'm running four Astak Mole cams, all are on wireless. I think these are 640 cams.
I've tried the "direct to disk" and there's not much difference. Getting ghosting in the recordings.
I set the Astak Mole cams to 10 frames per second, and set BI to 15 with no difference.
The desktop does not have wireless, so it's connected via Cat5. But the Cat 5 goes to a switch. Would it get better performance if I wired it right to the router?
SO, here's what I'm wondering. I have a HP laptop with an AMD A10-5745M APU, and 8 gigs of RAM. Would this laptop be fast enough to run four or five Mole cams with good recording quality?
Thanks in advance.
Thanks in advance.
