biggen
- May 6, 2018
- 2,957
- 3,397
A 3' fiber gap is plenty. When I've used fiber converters like that I would mount them right next to each other (not touching).They offer these with a 1m length for $55 or 30m length for $67. Which would be the better play? Would 3' of gap between the boxes be sufficient (knowing that they will likely both be plugged in within close proximity) or should I try to get them as far apart as possible? I am not opposed to running another receptacle across the attic if I need to for the second box to be at a distance.
It stinks you have to run power into your jbox now though since you can't power the switch via PoE.
