Usually new firmware means good stuff... However, being new to this world of IP cams, I know this can be a bad thing as sometimes they break more things than they fix. (at least my experience with foscam and Geeya)
That being said, I bought a used 2432 on ebay for 100 bucks from someone in OK and hopefully it works good and I won't have issues. I'm not sure what firmware it comes with (chinese or english, number etc) so I might want to update...
I'm curious what I have to do to make sure the camera works as properly intended with the best/latest firmware. Also how will I know if I need to install chinese or english version etc?
Camera will arrive on monday and it will be going to my living room to replace the crappy foscam that I have which I'm not happy with. I might replace this Geeya 801c in my room as well with possibly the new PTZ hikvision (or the 2032) and might be adding few more to my garage and outside by the door...
so anyways, my actual question is, how do I know what firmware to put and is it an easy process? (the foscam was very easy to update firmware)
Thanks!
I really hope it will deliver better performance over my foscam.
the 2432 will be connecting via wifi to a router which is about 30 feet away in my computer room. Unfortunately 2.4ghz is very busy around me so I might go PLA in the near future. the Geeya 801c showed 70% signal strength to it and streamed at over 20 fps with 720 from there. the foscam 8910W is lucky to get 8fps
Thanks!
