I ingeborgdot Pulling my weight May 7, 2017 721 171 Scott City, KS Jun 29, 2017 #1 I have my router port forwarded now until I get my new router with VPN but is there anything else I need to do before I spend $10 to get the app?
fenderman Staff member Mar 9, 2014 36,891 21,407 Jun 29, 2017 #2 ingeborgdot said: I have my router port forwarded now until I get my new router with VPN but is there anything else I need to do before I spend $10 to get the app? Click to expand... if you are going to buy the app anyways, just do it...its 10 dollars...youll survive...using blue iris without the app is like putting snow tires on ferrari in the summer.
I ingeborgdot Pulling my weight May 7, 2017 721 171 Scott City, KS Jun 29, 2017 #3 Yeah, I probably will but will it work now?
fenderman Staff member Mar 9, 2014 36,891 21,407 Jun 29, 2017 #4 ingeborgdot said: Yeah, I probably will but will it work now? Click to expand... yes, what else do you think you need?
bp2008 Staff member IPCT+ Member Mar 10, 2014 12,886 14,482 USA Jun 29, 2017 #5 If you can connect to Blue Iris's web interface then you can connect with the mobile apps, by entering the same address. Nothing else is required.
I ingeborgdot Pulling my weight May 7, 2017 721 171 Scott City, KS Jun 30, 2017 #6 Yep, it was pretty easy for sure. 30 seconds and I was on. This is a pretty nice app for sure. I would have gladly paid $10 instead of $9.99
looney2ns IPCT Contributor Sep 25, 2016 16,318 24,222 Evansville, In. USA Jul 2, 2017 #7 The BI app is AWESOME. Be sure to read help in the app for all the hidden gems. Reactions: fenderman
