I want to use a hikvision analog recorder instead of a dedicated analog encoder, specifically for use with blue iris. The usual rtsp:/<user>:<password>@<IP>:8554/Streaming/channels/10<1|2> works. Problem is in BI when you connect over RTSP you loose the option to have a main/sub stream for each cam. Is there another way to connect that would allow me to pull both the main/sub stream?
